That is done so that they can use that same connector for anything that requires 3 pins. In your case the three colors are Pink with a 12-volt feed on pin A, then a Purple that is a ground into the ECM on pin B, and lastly a yellow wire that is the sensor signal. The connector image is looking into the connector with it unplugged. The connections there need to be good. I use individual non-insulated crimp connectors and adhesive lined heat shrink normally like in this video:
https://www.youtube.com/watch?v=wqV-EyYDEAg
You can also use the combination crimp with heat shrink on it like the ones in this video:
https://www.youtube.com/watch?v=CRA0iE_qoYk
Both work well as long as you don't damage the insulation.
Apr 23, 2025 at 9:39 PM
