Crankshaft position sensor location
1996 CHEVROLET TAHOE
253,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
COREY H JENKINS
  • 80 POSTS
In an earlier question, I was told that the crankshaft position sensor was located behind the starter on a 1996 Tahoe 5.7 vortex.
Well I took my starter out and did not find CPS.
My question is where is my CPS located?
Aug 5, 2017 at 12:59 PM
HARRY P
  • 2,292 POSTS
It is not much of an image, but it is all GM provides. Hope it helps.
Aug 5, 2017 at 9:14 PM
COREY H JENKINS
  • 80 POSTS
Cannot really tell much with this picture.
Aug 6, 2017 at 3:03 AM
HARRY P
  • 2,292 POSTS
Yeah I know. It looks like it is on the left side of the engine next to the coil pack, bolted onto the block. I will try to see if I can find any other information later on.
Aug 6, 2017 at 5:18 AM
COREY H JENKINS
  • 80 POSTS
Thank you.
I will be watching for your next reply.
Aug 6, 2017 at 6:10 AM
HARRY P
  • 2,292 POSTS
This one makes more sense to me. It is where most cars have their crankshaft position sensors. It is right in behind the crank pulley, around the 7 o'clock position. I do not think that you should need to take the crank pulley off either. Does that help?
Aug 6, 2017 at 6:29 PM
COREY H JENKINS
  • 80 POSTS
That helps a lot.
Only now where is crank pulley?
Aug 6, 2017 at 6:47 PM
HARRY P
  • 2,292 POSTS
The crank pulley is the big one. Should be low down and in the middle.
Aug 6, 2017 at 8:02 PM
