It would be easy if you didn't have the AWD version, but Chrysler just had to stuff that PTU in there and not leave any room. Long crank and that code could be a failed sensor or a bad wire in the harness to it, I have also seen a bad cam sensor set that code. The simple test would be to unplug both cam position sensors and then see if it still starts as it can substitute the cam and crank signals with each other if one is missing. However even that isn't simple on your car because they stuck the left side cam sensor under the intake manifold! To remote test the sensors at the PCM connector requires either depinning the power feed wire at the PCM connector, or to use an oscilloscope to back pin test the sensors at the PCM. If you have access to a dealer level scan tool it might be able to read the signals through the PCM, but most people don't have those laying around.
If you do or know someone with one you might try that and see if it can tell you if the crank sensor is the problem.
Oct 12, 2025 at 1:55 PM
