Crankshaft position sensor location?
2007 CADILLAC CTS
150,000 MILES • 2.8L • 6 CYL • AUTOMATIC
LADYTLEWIS89
I'm just trying to find the correct location of the crankshaft position sensor for my 2.8 L V6. It's not available anywhere online, and especially not for the 2.8
Sep 21, 2025 at 9:52 PM
STEVE W.
  • 15,113 POSTS
It is in the right side of the engine block in line with the crankshaft and about 3 inches from the split line between the engine and the transmission. You have to access it from under the car, there is a heat shield and harness that need to be moved a bit.
Sep 22, 2025 at 4:21 AM
KRAKENAUTO
  • 39 POSTS
It looks like it is located on the passenger side towards the rear, just under the valve cover on the head. See the diagram I attached ref #2 is the sensor.
Sep 27, 2025 at 8:29 PM
