Trying to find the location of the crankshaft position sensor on my car listed above premier 2.0L turbo.
Aug 14, 2023 at 7:20 PM
CERTIFIED EXPERT
Here is the location of the crankshaft position sensor which is on the right side of the engine behind the starter motor. To begin, disconnect the negative battery cable to power down the system. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Aug 15, 2023 at 10:42 AM
K THOMAS
MEMBER
Thank you, I did find it and was able to replace it, I have another question on the same vehicle, it coded p00CA high pressure fuel regulator high voltage, could you tell me what that means, do I need a new fuel pump or is there something electrical?
Aug 16, 2023 at 4:31 PM
CERTIFIED EXPERT
Thanks for letting us know, we are here to help, please use 2CarPros anytime. We only handle one problem per thread, please post your new question here, you must be logged in.
