I have removed the screw securing the CPS, however the cylinder is seized up and I am unable to remove. The only thing I can think of to fix this would be, either, tap and drill screw into cylinder and then pry off however the catalytic converter is directly behind and in the way so in order to do that I believe the catalytic converter would need to be removed to even access the sensor or remove the oil pan and push sensor through. however, to do both of these jobs I believe I would need to remove catalytic converter. Is there any other way or trick I can do to remove the CPS rather than taking everything apart?
Mar 25, 2019 at 10:51 PM
