Good morning,
This code is for the crank sensor but the checks need to be done to verify proper voltages are being sent and received from the sensor. I attached a flow chart and a picture of the sensor for you.
DTC P0336 CRANKSHAFT POSITION SENSOR "A" CIRCUIT RANGE/PERFORMANCE
DTC DETECTING CONDITION:
- Detected when two consecutive driving cycles with fault occur.
- GENERAL DESCRIPTION See: A L L Diagnostic Trouble Codes ( DTC ) > Diagnostic Trouble Code Descriptions > P0336
TROUBLE SYMPTOM:
- Engine stalls.
- Failure of engine to start
CAUTION: After repair or replacement of faulty parts, perform Clear Memory Mode. See: Computers and Control Systems > Reading and Clearing Diagnostic Trouble Codes > Clear Memory Mode and Inspection Mode. See: Computers and Control Systems > Scan Tool Testing and Procedures > Preparation For the Inspection Mode
WIRING DIAGRAM:
Aug 6, 2019 at 9:30 AM
