Location of Crankshaft position sensor
2007 SATURN VUE
150,000 MILES • 3.5L • V6 • AWD • AUTOMATIC
JEN EGGEN
I need to replace the crankshaft position sensor on my car. Where exactly is this located?
Jul 19, 2016 at 2:42 AM
WRENCHTECH
  • 20,761 POSTS
The crankshaft sensor is behind the timing belt so it is a very large and technical job that requires removing the timing belt. You should also plan on installing a timing belt kit in the process. If you have never done a timing belt on an engine like this you may want to enlist professional help. One mistake in this area can cost you an engine.
Jul 19, 2016 at 3:14 AM
