Crankshaft position sensor wires?
2008 NISSAN 350Z
180,000 MILES • 3.5L • V6 • 2WD • MANUAL
Z33JU
I’d like to know which directions the wires to the crankshaft position sensor go. I have 3 wires that are red/green/yellow. I do know which way to wire them so the sensor functions correctly.
Aug 21, 2025 at 8:02 AM
If you hold the connector on the sensor so that the locking clip/tab is on TOP (facing you, latch at the top edge), the pin layout is:
Pin 1 (Left) = Ground (Red/Yellow)
Pin 2 (Middle) = Signal (Green)
Pin 3 (Right) = Power 12V (Red)
Let us know if you need anything else.
Aug 21, 2025 at 10:17 AM
