The sensor, which is behind the starter motor, is mounted inside the engine block so oil on it would be normal. However, I'm not sure why you would have oil in the connector.
If you clean and dry it, does it get wet right away once the engine is started? Are there any leaks from above the sensor such as the valve cover gasket?
Let me know. Also, I attached a pic below showing the sensor's location. Is that the one you are referring to? Are there drivability issues?
See pic below.
Dec 7, 2023 at 9:19 PM
