crankshaft play
2010 FORD F-150
200,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BLAZEJ
  • 4 POSTS
Hi.
I'm from Poland and this is my first time repairing an engine like this. Your videos are great and have helped me a lot.
In the video (How to Build a Ford 5.4L 3V Engine - Part 4: Clean and Crankshaft Install) at 32 minutes you check the clearance along the crankshaft? What is the allowable clearance? My engine has 0.55mm of clearance, despite new bearings. Are larger bearings available to reduce the clearance?
Aug 31, 2025 at 1:01 PM
MECHTRIX
  • 382 POSTS
Yes there are many bearings that will correct the clearance ..but first measure everything 3 time from different angles and write down the results for each one .. so to start
Are you sure of that measument ? 0.55 is a bit more than a half mm
Woch would be way out of tolerance that would be 21.7 thousnths of an inch wiich is crazy out of tolerance...
So check the and right it down and let me know becuase if it was 0.055mm then ot would be 2 .2 thousands that would be good so please check it and while you doing this job right everything down there gonna be quite alot to record as you move forward ...let us know the truest measurement you get ok ? while we look up the specs for you ..thanks
Aug 31, 2025 at 1:26 PM
MECHTRIX
  • 382 POSTS
So the crankshaft main bearin journal
clearance specs
Is 0.024 to 0.048 mm ... if you need anything else let us know good luck
Aug 31, 2025 at 1:51 PM
BLAZEJ
  • 4 POSTS
Yes, I'm sure about this measurement. I know it's a very large clearance. The crankshaft has been repaired. I'll try to find or fabricate oversized bearings. Please tell me the correct clearance.
Aug 31, 2025 at 2:18 PM
MECHTRIX
  • 382 POSTS
All sizes are availible
If you have a crankshaft machinist near you I'd just have the ground back to standard and use standard sized bearings ...also might have it balanced while you're at it
Good luck
Aug 31, 2025 at 2:23 PM
BLAZEJ
  • 4 POSTS
I'm talking about the clearance on the thrust washer
MECHTRIX
  • 382 POSTS
Ok that's different the endplay clearance is 0.075 to 0377 mm good luck
Aug 31, 2025 at 2:26 PM
BLAZEJ
  • 4 POSTS
You helped me a lot. Thank you.
Aug 31, 2025 at 2:28 PM
MECHTRIX
  • 382 POSTS
Glad to help enjoy your project if theres anything else let us know be well"
Aug 31, 2025 at 2:32 PM
