Hello, right now it is currently throwing six codes. I have been chasing a misfire all over this engine and cannot seem to get it under control. It is throwing a cylinder five and six misfire as well as a random misfire. It is also throwing and cylinder two and seven fuel injector circuit malfunction code. Everyone has said that the problem is occurring from the crankshaft sensor going bad. The original misfire was two and four, then five and seven. Now this! Please help? Also, if you go to drive after starting the engine as soon as you go into gear the engine stalls and you have to hold the gas pedal down all the way to get it to start and you have to keep pressing the gas until the engine finally idles on its own. What is going on?
Jan 9, 2018 at 11:55 AM
