Recently replaced the timing chain. But when I started the car, it ran rough and threw a p0017 code. When I did the procedure the first time the cam sprockets were at the 2 o’clock position for the intake cam sprocket and the exhaust cam sprocket was at the 10 o'clock position. So, I decided to redo the timing procedure to correct the timing but not I have the crank key at 12o clock position at TDC, the cams are not in the right place. How do I get the cans to rotate to the correct positions?
Aug 14, 2023 at 4:27 AM
