Cranks runs for a second then shuts off
1991 DODGE DYNASTY
140,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
JESSIE69
I have replaced the fuel filter because of bad gas and ever since once it gets down to a 1/4 tank of gas it wants to bog down. When making left turns I was down to a quarter tank and stopped to get gas put a total of nine gallons of gas in and it cranks but does not run long enough to get it in drive. I can hear the fuel pump when turning on the switch. What could be the problem?
Oct 24, 2018 at 7:43 AM
CARADIODOC
  • 34,306 POSTS
There is two possibilities. If the engine runs for about two seconds, then stops, it is likely in anti-theft mode. To disarm it, unlock either front door with the key, or with the key fob if you have one.
If the battery was recently disconnected or run dead, the Engine Computer needs to relearn "minimum throttle" before it will know when it must be in control of idle speed. A very specific set of conditions must exist for that relearn to take place. To meet those conditions, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
You will need to hold the accelerator pedal down 1/4" to keep the engine running. Until minimum throttle is relearned, the engine will also tend to stall at stop signs.
Oct 24, 2018 at 10:38 AM
JESSIE69
I will try both and let you know if one of these works for me
Oct 24, 2018 at 6:31 PM
Please do CARADIODOC is one of our best!
Oct 27, 2018 at 12:14 PM
JESSIE69
The only code i got was 13 no charge in MAP then battery died I let it charge and haven't had an issue since and I was told a bad MAP censor could cause the car to act like it was a bad fuel pump if I have anymore problems I will definitely come back here first this was very helpful thanks
Oct 28, 2018 at 3:29 AM
Yep a bad MAP can cause all kinds of issues. Please let us know if you need anything else to get the problem fixed.
Oct 28, 2018 at 11:05 AM
