Okay. So if the theft system is not on and you can't get codes then we have to try and solve the fuel or spark issue and hope that when we fix one it fixes the other.
So let's go to the distributor and see if you are getting the signal from the ECM. My guess is that you are not. If you are not, then we need to inspect the cam shaft sensor. I attached the testing for that so let's see what turns up and go from there.
Nov 9, 2020 at 5:47 PM
