Hello tech's, i have a problem with my wifes 2000 Civic EX. I'm am desperate for any ideas at this point. The problem started one morning when she was leaving for work, car turns over but no fire. I checked for spark and nothing.
I tested voltage going to the coil and it shows 12 volts, so i assume that means the problem is in between the coil and the plugs. I replaced the Ignition Control Module and still no fire. So i replaced the entire distributer (coil, module everything), cap, rotor, and spark plug wires today, and still no spark. Cam is turning, timing belt looks good.
No CEL or anything showing signs of trouble prior to this.. Only thing wrong with the car prior to this was the cruise control stopped working about 2 or 3 months ago.
Any ideas i would GREATLY appreciate!
Thanks
al
Nov 2, 2020 at 1:23 PM
(Merged)
