Cranks, needs starter fluid to start
1991 CADILLAC DEVILLE
144,000 MILES • V8 • FWD • AUTOMATIC
VIETVET66
  • 9 POSTS
Shuts off, cranks will not start, I used starter fluid in throttle body to restart, fuel pump replaced, and filters, ejectors replaced, ECM replaced, intake gaskets, temperature sensor all replaced. Two different shops, can not fix it. It will idle all day and never die, take it on road, and it will run rough, go to stop for a light and it shuts off, and will not restart use starter fluid and it will get you home.
Aug 23, 2016 at 3:13 PM
WRENCHTECH
  • 20,761 POSTS
I would smoke test it for vacuum leaks. Also check the accuracy of your temp sensors with a scan tool.
Aug 23, 2016 at 3:26 PM
VIETVET66
  • 9 POSTS
I can smoke test it, I do not know if I can check the sensors, but I am not getting any codes, if I had a leak would not a code come up?
Aug 23, 2016 at 4:53 PM
WRENCHTECH
  • 20,761 POSTS
It is easy to check the sensors with a scan tool.
Check it after it has been parked overnight. Look at sensor data and the IAT and ECT should read ambient temperature and be withing a couple degrees of each other.
Aug 23, 2016 at 5:06 PM
WRENCHTECH
  • 20,761 POSTS
Within (typo)
Aug 23, 2016 at 5:07 PM
VIETVET66
  • 9 POSTS
Thank you, I will try it.
Aug 23, 2016 at 7:34 PM
RENEE L
  • 1,260 POSTS
Please let us know how it goes so it will help others
Aug 30, 2016 at 10:19 AM
VIETVET66
  • 9 POSTS
Finally had time to smoke the Caddy, but no leaks that I could see, as far as the sensors, I can not do that it would have to be done by a garage, I am not getting any codes.? If the sensors do check out what else would cause it to stall out and just crank and not start, unless of course you spray starter fluid in the throttle body.
Also does spraying starter fluid into the throttle body hurt it.?
Sep 1, 2016 at 2:24 PM
WRENCHTECH
  • 20,761 POSTS
All "crank, no start" conditions are approached in the same way. Every engine requires certain functions to be able to run. Some of these functions rely on specific components to work and some components are part of more than one function so it is important to see the whole picture to be able to conclude anything about what may have failed. Also, these functions can ONLY be tested during the failure. Any other time and they will simply test good because the problem isn't present at the moment.
If you approach this in any other way, you are merely guessing and that only serves to replace unnecessary parts and wastes money.
Every engine requires spark, fuel and compression to run. That's what we have to look for.
These are the basics that need to be tested and will give us the info required to isolate a cause.
1) Test for spark at the plug end of the wire using a spark tester. If none found, check for power supply on the + terminal of the coil with the key on.
2) Test for injector pulse using a small bulb called a noid light. If none found, check for power supply at one side of the injector with the key on.
3) Use a fuel pressure gauge to test for correct fuel pressure, also noticing if the pressure holds when key is shut off.
Once you have determined which of these functions has dropped out,
you will know which system is having the problem.
Sep 1, 2016 at 3:01 PM
VIETVET66
  • 9 POSTS
That is the problem if it happens on the road, I need to get it out of traffic, which means using starter fluid.
Than of course the problem may be gone, I have a good size extra lot at the house I may have to drive it until it happens, then go through the list. You are right about guessing that is all the shops have been doing and it has cost a small fortune, Thank you for the good advice Wrenchtech, it may take me awhile
until I can get it to happen and then check it out.So if you don't hear from me I am still working on it. But I will let you know.
Sep 1, 2016 at 5:07 PM
WRENCHTECH
  • 20,761 POSTS
You are 100% correct but welcome to our world. This type of problem is probably one of the toughest things to diagnose. You have to have all your equipment ready or already set up when the problem rears it's head. If it stays dead long enough to test, you're in good shape.
Sep 1, 2016 at 5:12 PM
WRENCHTECH
  • 20,761 POSTS
Remember, just because you have narrowed it down to fuel, you still don't know if it's a fuel pressure or an injector issue
Sep 1, 2016 at 5:15 PM
VIETVET66
  • 9 POSTS
When I start I will have everything ready Thanks again for your quick response and help
Sep 1, 2016 at 6:08 PM
Please let us know how it goes so it can help others.
Best, Ken
Sep 3, 2016 at 12:09 PM
VIETVET66
  • 9 POSTS
Will do
Sep 3, 2016 at 5:19 PM
VIETVET66
  • 9 POSTS
Set up the pressure gauge, and tried driving in the lot, but I can only get it to 15 or 16 mph, so I will have to take it on the road anyway, will post what happens, the gauge read 35psi whenI started it and stayed there for quite awhile after shut off.
Sep 11, 2016 at 4:27 PM
It sounds like you may have a plugged exhaust system, try looking over these articles to see if they will help:
https://www.2carpros.com/articles/engine-has-low-power-output
and
Please let us know what you find so it will help others
Best, Ken
Sep 14, 2016 at 2:54 PM
VIETVET66
  • 9 POSTS
Ken, I guess I didn't explain myself about the 15 to 16mph, the lot is only 100x200 so it is to small to get any speed as far as fuel pressure I am not sure what it should be but 35psi to 40 is what the gauge showed, I still need to take it on the road to test it out. Thanks for the reply, will keep you informed.
Sep 14, 2016 at 4:56 PM
Hey VIETVET66,
Did you ever get the problem fixed?
Dec 21, 2016 at 1:40 PM
VIETVET66
  • 9 POSTS
Sorry I have not got back to you all, no the problem is not fixed but it has not happen again at least not yet, the wife has said she wants to sell it so I will drive it around town with a for sale sign on it. If I ever find out before it is sold I will be sure to tell you all.
Dec 21, 2016 at 6:46 PM
