So, I replaced the PCM and changed the valves and head gaskets. got ti back together and it started turning over and started when i gave it some gas but stalled out after a second. I only tried it a couple of times then let it sit until the next day. When I attempted to start it, I turned the key and the lights all worked and i heard the fuel pump but that's it. I think there is a click from the relay but it's hard for me to hear from the cab. The battery is charged and the starter cranks when I jump it at the relay. I tried pulling a spark plug out and it's not sparking when I manually crank the starter. I'm guessing it's the PCM again? The crankshaft positioning sensor seems to be working I pulled it out and ran metal in front of it. it seemed to be less responsive than I would expect it to be and the same goes for the camshaft position sensor.
Oct 28, 2023 at 8:15 AM
