Cranks flutters shuts off
2001 SATURN SC1
192,000 MILES • 2.2L • 4 CYL • 2WD
CASSIE BROWN
I can crank my car over but it will not stay running it will flutter and then shuts off. At first I thought it was the fuel pump but I checked my voltage voltage is good feel pressure is strong. There is a fuse that keeps blowing in under hood relay block, but I cannot find a diagram for a fuse it is.
Nov 4, 2018 at 6:47 PM
Can I ask if the security light is flashing? If not let's check the spark because it sounds like you may have a crankshaft angle sensor that is out. We should run the codes as well.
Here are two guides to get us started:
and
Nov 6, 2018 at 10:48 AM
