The truck listed above is a 1500. Truck ran fine until the fuel pump went out. I replaced the fuel pump now it won’t start. It cranks over good and acts like it wants to start but it won’t. good spark and 60 PSI to the rail. Check engine light is on. Hook a scanner up to it scanner reads it has no codes. I deleted the “codes”, and the check engine light went off. Cranked the truck over once and the check engine light came on. Hooked the scanner back up and the scanner still reads no codes found. Anyone have an idea on why the truck won’t start and run?
Jul 3, 2022 at 6:57 PM
