Cranks but won't start filled the tank yesterday?
2005 HONDA PILOT
285,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
THEMAILMAN
  • 102 POSTS
This is my father in laws car. He filled the tank yesterday. Drove it home around the block. And when he went to move it a few minutes later it cranks but won't start. I can hear the fuel pump run but it doesn't start. Being that it happened right after filling the tank in thinking bad fuel pump. I want the fuel pump test procedure and any other thoughts/things to check and so forth. TIA.
Nov 8, 2025 at 3:41 PM
That is a good place to start, here is a video to help you with the testing, you can rent a gauge set at the auto part store for free, also how does the engine sounds while cranking? If you upload a short video of the engine cranking from under the hood I can tell you if it is on good shape or not.
https://www.youtube.com/watch?v=kgEixCsqcYM
Fuel pressure .................... 390 - 440 kPa (4.0 - 4.5 kg/sq.cm, 57 - 64 psi)
Also, I would go over this video which can help guide us to the source of the non starting issue.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Please go over these guides and get back to us.
Nov 10, 2025 at 9:50 AM
THEMAILMAN
  • 102 POSTS
Before actually getting the gauge I pulled the line off and simply turned the key on. It sprayed a good bit. I tinkered around. Then he handed me a different key and the same thing fired right up. Bad key. Problem solved. This is why I drive even older cars
Nov 18, 2025 at 2:08 PM
Good call! So was the security light flashing? This would be a clue the key was not working correctly. Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Nov 19, 2025 at 8:36 AM
