cranks but will not start
1996 MERCEDES BENZ E320
113,000 MILES • 3.2L • 6 CYL • 2WD • AUTOMATIC
S&I
First I changed the lower arm control because it broke, then it stalled out a couple of times, it's cranked but won't start, I changed the camshaft valve, and all three ignition coils, I have power but no spark, I checked all the wiring, the fuses and relays, everything is good. Another problem that is not that many relays and this vehicle listed above W210, also it would be helpful if somebody can recommend a diagnostic tool for this car.
Nov 29, 2019 at 3:43 PM
Will the engine run on starting fluid? When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
This guide will help us get started on fixed the problem:
Dec 1, 2019 at 2:56 PM
