Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lexus
RX 350
Engine
Symptoms
Not Running
Cranks but will not start after overheating
2008 LEXUS RX 350
179,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
FORRANDY3
MEMBER
1 POST
FOLLOW
After overheating car never wanted to restart again.
May 12, 2021 at 7:28 AM
CERTIFIED EXPERT
This sounds like we have a compression issue.
Here is a guide that will help with this in general:
https://youtu.be/dCjmRL3p4Cs
However, I would start with testing the compression using this guide:
Also, you can test the head gasket as that would indicate the issue as well.
Let's run through this info and go from there. Thanks
May 13, 2021 at 6:09 PM
