Came home from work, and the car ran fine. No engine codes, just the evap / gas cap.
Went to start 2 days later, cranks but won't start. Battery at14.5 volts, fuel pressure at55 PSI, getting spark / tested all four plugs, plugs are less than 6 months old and gapped fine. I removed the valve cover to observe that the cam is turning, so I know the timing belt is intact. Used my obd scanned to check the map sensor is reading.
Any suggestions?
Any suggestions?
Dec 30, 2024 at 9:15 AM
