Hi I did go get a scanner 100.00 from auto zone as california won't allow them to rent them anymore.I have never used one before but it said OEM enhanced live data is not supported by this vehicle. Also said Class 2 Data Link Malfunction. U1000 (1/44 Not Passed S C ). I think I'll start at the very beginning about a month ago one day all my warning lights started reading wrong- like out of gas, overheating to the top, I went to an electrical shop he said it was the after market security, that they do a couple a week-he discounted it or removed it?? and came to me and said it didn't fix the problem-maybe in the original factory security in the computer. It drove well so I just keep driving it like that for a few weeks and the gauges would change at will. I actually was on my way to auto zone to get a scanner check from them, turned it off before i had got there and cranked good and like tried to start ( like run a second or two) but would not start, towed it home. Since than I've tried alot, but what I wonder about is during this time of no start it started up one time I drove it around my house etc. ran great until I turned it off and has not started again since. It has gas, spark to the plugs, can hear fuel pump come on and humm. It still will sometimes run like a second and I give it alot of gas but won't keep running. I have many ,many times did all the security tricks, now mostly the security light comes on solid, in about 2 or 3 seconds it goes off and other warning lights go off with it. I believe my friend that first checked everything said injectors won't getting anything. I did replace the fuel pump relay and check the fuses.I was told it is most likely a body control module but since they are rather expensive I really wanted your opinion- especially since it started once and almost acts like it's going to start but not getting gas. Thank you alot for your help-Desert Lady
Sep 27, 2017 at 5:07 PM
