Cranks but no spark
1999 DODGE CARAVAN
260,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
JEFFREY WOOD
  • 4 POSTS
Cranks, no spark at plugs, no power at coil pack. Was running until it had run out of fuel. Now has fuel with 50psi at fuel bar and compression; still no spark. Tried a different coil pack but no change. Other activity on vehicle was changing a clock-spring due to horn going off even with nobody near vehicle!
Jul 9, 2019 at 1:58 PM
JEFFREY WOOD
  • 4 POSTS
Vehicle has no codes from me disconnecting battery multiple times. I have test light, multi-meter and hand tools.
Jul 9, 2019 at 2:03 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your vehicle's Crankshaft Position Sensor (CKP). Your vehicle's Power-train Control Module (PCM) or "computer" uses the signal from the CKP to signal the fuel injectors and the spark plugs when to fire. Without this signal your vehicle will not start. In the diagrams down below I have included a description of your vehicle's CKP and instructions for the removal and installation of it. Please go through these guides and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Jul 9, 2019 at 3:25 PM
JEFFREY WOOD
  • 4 POSTS
Thank you, I will be checking this out tomorrow morning and post my results.
Jul 9, 2019 at 5:36 PM
Jul 13, 2019 at 12:49 PM
JEFFREY WOOD
  • 4 POSTS
I have since found there is an intermittent broken wire in the harness at the front of the vehicle, next to the radiator on driver's side. I shifted the harness and the van tried to start and had spark! Now the drudgery of going through the harness to test which wire(s) are bad; thinking of noting color-combos of wires to the camshaft sensor, crankshaft sensor, EGR sensor and coil pack to narrow down the number of wires to check in this 1.5" bundle of wires. Not that easy with a tedious chore ahead of me but at least I located the possible issue!
Jul 13, 2019 at 2:40 PM
Good to hear, please use 2CarPros anytime we are here to help. Let us know what happens.
Jul 15, 2019 at 11:09 AM
