Welcome to 2CarPros.
What you described sounds like a bad crankshaft position sensor. When they go bad, often times it will start with stalling when the engine gets warm. When the sensor goes bad, ignition spark to the plugs is lost. It could be fuel related too. The easiest way to check for spark and fuel to the engine is to see if it will start with starting fluid. If it does for a couple seconds, then we know it has spark and is a fuel related issue. If it doesn't even try to start with starting fluid, chances are the is no spark to the plugs and it is ignition related.
Take a look through these links:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Now, will add another thought that I would recommend checking before replacing the sensor. On these vehicles, all coil packs have a common ground. The ground runs through the harness above the intake and then one black wire runs down the driver's side of the engine toward the front of the engine. Aprox below the second cylinder back on that side. Check to make sure the wire is attached, not damaged, and not corroded. Often times they can look good but as soon as you touch the connector, they break.
Here is a link that you may find helpful. It explains how to check for ignition spark. If you find there is no spark, I suspect one of the above issues is the cause.
___________________________
If you could do these tests and let me know the results, I can better guide you to a repair.
Let me know,
Aug 8, 2019 at 8:34 PM
