Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Saturn
L300
Engine
Symptoms
Not Cranking Over
Cranking but will not turn over
2003 SATURN L300
136,000 MILES • V6
WALIK
MEMBER
FOLLOW
I changed the crank sensor and ECM car was running fine now it will not start. It cranks and shuts off.
Feb 13, 2018 at 6:09 PM
SATURNTECH9
CERTIFIED EXPERT
With the key in the run position is the security light on solid or flashing on the dash?
Feb 13, 2018 at 7:29 PM
WALIK
MEMBER
Solid.
Feb 17, 2018 at 5:14 AM
CERTIFIED EXPERT
It sounds like you will need to have the new sensor programmed in the PCM. A shop can do it for you for about $65.00.
No spark right?
Feb 19, 2018 at 12:19 PM
