Okay, so not sure what I am missing. Hoping you will shed some light. So this is concerning the truck listed above Z71 Stepside, extended cab pickup that has the 5.7 Vortec. I have pretty much rebuilt this thing. I had the spider injection go bad on me and when my mechanic said it was to be over $900.00 for him to repair I had to opt to repair it myself. So have installed a brand new spider injector and after reassembly the truck fired right up after charging the battery only ran poorly. I went ahead and replaced the plugs and wires and after a small move of the distributor I had the truck running again. I just left the truck running that day because I am trying to let the gas that did reach the oil to burn off as suggested by one of your guys. Anyway after running for quite a while the truck shut off and would not restart so I just chalked it up to I had ran it out of gas. 4 or 5 days later I finally got a ride to get more gas, which I just got $10.00 worth and put that in the truck. Well I cranked and cranked it and it would not start. So I pumped the gas pedal to the point it should have been flooded. However I couldn’t even smell gas at all so I noticed it was getting fuel and I couldn’t hear the fuel pump kicking on so I went ahead and replaced the fuel pump, fuel filter (which does not have the arrow and the word flow on the side of it instead it has in on one end and out on the other end) and the fuel relay. Still cranking without starting. I can hear the pump kicking on again, I have disconnected the fuel filter and gas came out of it and when I push in the pin on the relief valve some gas comes out on top of the motor. I also disconnected the ground wire and scraped and sanded the section of the frame so that it is for sure got a good connection. Really frustrated at this point and not thinking straight I guess so hoping you can direct me to what I am over looking.
Jun 14, 2019 at 12:02 AM
