Can you tell me where the crankshaft position sensor and the camshaft position sensor are on the vehicle listed above 4 door with the 4.7 L motor? And the procedure to replace them. I got a Noid light setup would this cause the noid light to not blink at all meaning I guess no fuel or spark being delivered. Only tested #1 injector should have tried a couple more I guess from what I’ve read. The OBD2 reader says it’s the camshaft sensor circuit malfunction. Does that mean the camshaft sensor needs to be replaced? Or what exactly does it mean camshaft sensor circuit?
Jul 23, 2021 at 12:09 PM
