Crank will not start
2001 AUDI S6
36,000 MILES • 4.2L • V8 • 4WD • AUTOMATIC
SHOGCAR
  • 4 POSTS
No current on fuse 32/ 34 plug did not spark, no current on crankshaft sensor. also, no ground on crankshaft sensor.
Mar 11, 2018 at 1:35 PM
It looks like you lost the ignition switch, but to confirm the issue follow this guide to test through the switch.
Here is the wiring diagrams so you can see how the system works and the ignition switch removal diagrams
Check out the diagrams (below).
Mar 13, 2018 at 11:15 AM
