Used a plug in tester that suggests changing the crank shaft sensor.
I've done this and the car is still only cranking and not firing up.
Would the car have two sensors that look identical and I have changed the wrong one?
I've also managed to have the car fire up briefly when spraying starter into air intake.
So I presume the fuel is just not getting were it needs to be. help!
Oct 5, 2019 at 2:21 AM
