Hello, I have a code p0339 intermittent crank signal. i'm on the west coast and did an engine remove and replace. The engine is from the east coast. This code is new to the vehicle and I've changed crank and cam sensors with OEM sensors. even swapped PCMs. The questions are is there supposed to be supply and signal voltage with key off (this is also intermittent) at the crank sensor harness connector? Could the east coast flywheel/reluctor ring be a problem causing this intermittent issue?
Jun 3, 2022 at 2:23 PM
