Engine turns, no spark, no fuel. Just replaced plugs, wires, cap, rotor, and coil.
Jun 1, 2023 at 9:24 AM
CERTIFIED EXPERT
The crankshaft position sensor (CPS) on a 1995 Chevrolet Cheyenne is located on the front of the engine, just below the harmonic balancer or inside the ignition distributor
Jun 2, 2023 at 7:39 AM
SILVERSAC
MEMBER
Thank you for the reply Ken.
Unfortunately after some more research. This truck has a 1993 7.4L in it. So, new question is.... is there and where is the crank sensor located on a 1993 454 small block?
Jun 2, 2023 at 8:19 AM
CERTIFIED EXPERT
The crankshaft sensor is inside the distributor. Please check out the images below.
Image (Click to enlarge)
Jun 3, 2023 at 9:25 AM
SILVERSAC
MEMBER
Thank you. Great information, very helpful. Replaced and truck started and runs great.
Appreciate your time.
Jun 3, 2023 at 4:20 PM
CERTIFIED EXPERT
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
