My car had a bad rod bearing so I went to a local salvage yard and found a 2008 Pontiac G6 with only 85,000 miles on the engine. so I put it in my car (listed above) and got everything hooked up and working except the crank sensor. the ECM is not receiving any input and I am not sure if the sensor is not compatible with the old computer. so I swap sensors from the old engine and still no signal what could be the problem be. I have a pretty good idea on how crank sensors were, but they both fit in the engine and plug in to the socket. however, the computer does not pick up a signal from either one. I tested the circuit and it is good.
Feb 14, 2017 at 9:30 PM
