Yes, it can. You should be able to get a replacement Crankshaft Position Sensor [CKP] and a new CKP electrical connector pigtail at your local auto parts store. Disconnect the negative battery terminal to your battery and snip on of the wires going to the CKP electrical connector. Using a good quality butt connector, splice the exact wire on the new CKP electrical connector to the vehicle's wiring harness. Repeat for all the wires then reconnect the negative battery cable to the battery. In the diagrams down below I have included the instructions from the vehicle manufacturer for the removal and installation of your vehicle's CKP. Please go through this guide and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Dec 18, 2019 at 11:50 AM
