Hey guys, it all started when my girlfriend was going to the store and came out and would hardly start. she had pulled over because it wouldn't go above 5 miles an hour. The ETS light was flashing, so we go it home and parked. I ran a test on it refer to Pic 1 and changed the crank sensor it and it started right up. went to test drive it and the check engine light came on and I took it back home and it started acting like it didn't want to start. so, I had unplugged the circuit wires to the crank sensor the throttle position sensor and the cam sensor and cleaned the connections it stated running better, but still had all these codes. I checked the wiring harness no cuts or blemishes, but I took my multi meter and checked the voltage no crank to the crank sensor and got 5.7 volts. I don't know what is going on. any help?
Feb 7, 2022 at 9:45 PM
