No. The Front Main or Front Crankshaft seal is usually a lip seal that goes around the crankshaft. The Crankshaft Pulley or Harmonic Balancer is attached to the front of the crankshaft but is precision machined and much to heavy and is almost pressed onto the crankshaft so that no matter what the serpentine belt does it would not cause any type of off balance play that would cause damage to the Front Main Seal. Also the crankshaft is held in place by the main bearings and they are machines to the thousands of an inch to ensure that the crankshaft is true. If you should have any other vehicle related questions, please, feel free to ask.
Thanks,
Alex
2CarPros
May 17, 2019 at 4:31 AM
