My timing belt snapped and water pump seized .i replaced both and car wont start.it sounds like it wants to start then crank pulley wont turn.
Feb 14, 2017 at 12:09 AM
MHPAUTOS
CERTIFIED EXPERT
You may have bent a valve and this is locking up the engine, can you advise which engine is fitted and then i can tell you if it is an interference engine, these engines will touch valves if the belt brakes.
