Where is the crank position sensor located?
2005 MERCEDES BENZ CLK320
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
car starts fine, no code other than the crank sensor. stays running for 10 minutes then goes off and hard to start until it's cool again. I had similar issues with other Benz and was the sensor...do you think so? Where is it located?
Nov 3, 2023 at 9:01 AM
Yep, it sounds like the crankshaft position sensor is bad which is located at the rear of the engine on the driver's side. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Nov 3, 2023 at 11:07 AM
BHAMDOC1973
  • 2,008 POSTS
Thanks.
Nov 3, 2023 at 11:18 AM
You are welcome, please use 2CarPros anytime we are here to help.
Nov 5, 2023 at 10:51 AM
