Where is the crank shaft position sensor located?
2012 NISSAN CUBE
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
NOE MAURICIO DELGADO
Crank shaft position sensor location needed.
Mar 2, 2025 at 9:34 AM
I fixed it.
Mar 2, 2025 at 11:06 AM
The crankshaft sensor is located down low on the block, near the rear, under the exhaust manifold. Check out the images (below). Let us know if you need anything else.
Mar 2, 2025 at 1:21 PM
