I had a random misfire. So, i replaced the injectors. With a very cheap set. After that I started getting crank no starts. So, I replaced the injectors with new OEM. I also replaced the fuel pump, filter, pressure regulator, engine coolant temperature sensor, crankshaft position sensor, camshaft position sensor, mass airflow sensor. I’m still having the crank no start issues. Shops cannot figure it out. I didn’t have this till cheap injectors.
Jan 31, 2023 at 4:04 AM
