Is the security light flashing when you try to crank the engine over? If so, this is the problem because the computer will cut the ignition when in security mode. This guide can help us reset the system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
Also, this guide has some good information as well:
https://www.2carpros.com/articles/car-not-running-advanced
You can try a hard reboot which is done by removing the negative side of the battery, with the cable loose from the negative side of the battery, hold it to the positive terminal for 1 minute this will discharge the memory capacitors in the BCM and PCM allowing the system to reboot.
Aug 2, 2022 at 9:11 AM
