This truck will not start, No cross firing, New plugs and wires
1997 CHEVROLET S-10
89,585 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MIKEY300ZX
  • 10 POSTS
This truck came to me for repairs over the last weekend. It has proper fuel pressure,spark and engine timing. New intake gaskets. New ICM, CKP,and CMP. I have a 5 volt reference voltage to most of my engine management sensors. This truck will not start. No cross firing. New plugs and wires. Also coils are new. Scan tool data says calculated load at 100%. And rear 02 has no voltage and is new also. Also has new FPR. Any help would be greatly appreciated!
Oct 1, 2016 at 7:53 AM
HMAC300
  • 48,601 POSTS
check security system or try another key maybe a bad key don't use a new one.
Oct 1, 2016 at 1:05 PM
MIKEY300ZX
  • 10 POSTS
No security light on. Also there is spark and fuel. If it was passlock related there would not be either.
Oct 1, 2016 at 1:12 PM
MIKEY300ZX
  • 10 POSTS
I do appreciate the reply though.
Oct 1, 2016 at 1:13 PM
HMAC300
  • 48,601 POSTS
how about a bad map sensor I remember a while ago that a bad map would not let a vehicle start.or try to start with in open loop with sensor disconnected. also some ECT sensors would do that. one last thing how about compression?
Oct 1, 2016 at 1:34 PM
SATURNTECH9
  • 30,869 POSTS
Just to add to this one what we're the compression readings ?Also what is etc readings is it within10 degrees of actual coolant temp verus ecm temp readings?Also we have injector pulse?SO you don't have voltage to the rear o2 sen
Oct 1, 2016 at 6:29 PM
Yes, unplugging each vital sensor one at a time might help, It sounds like the ECM is bad if all sensors are not getting the 5 v reference though.
I would start with a pin to pin on the ECM to make sure all power and grounds are right, then I would replace the brain, it sounds like one of the drivers has gone out
Please let us know what you find so it will help others.
Best, Ken
Oct 1, 2016 at 6:30 PM
MIKEY300ZX
  • 10 POSTS
Ecm is fine. Not all sensors get 5v reference some use 10-12 v that's what I was saying. Also have not checked compression. I don't suspect a compression problem as it was running earlier today just fine. Have swapped a known good ecm and had same issues.MAP readings are 29.5 HG KOEO. Omv to rear o2 sensor. 5.5 degrees ignition advance. Calculated load 100% all the time. Front o2 .450 mv. Injector pulse is fine. All grounds that I have seen check out. From what I can see its related to the rear o2. No voltage means its inactive. The injector pulse seems too long to start cold. Way too rich. Also tried un plugging things while looking at engine load. Nothing changed. I appreciate all the input guys.
Oct 2, 2016 at 5:11 AM
MIKEY300ZX
  • 10 POSTS
Also temp sensor is within 2 degrees of outside temp so its good I have seen them fail at-20 though. I'm going to test compression next. Seems like either spark at the wrong time or too long injector pulse. The engine will backfire. But wont start as if the timing is off. But its dead on. And the valves are all operating correctly.( Camera inspection tool).
Oct 2, 2016 at 5:16 AM
MIKEY300ZX
  • 10 POSTS
I just unplugged the front o2 sensor and it has 0.450mv even unplugged. Rear o2 has no 12 heater power at harness. But no code for that. Gonna look into the harness for now. I've done everything else I can think of.
Oct 2, 2016 at 5:25 AM
Good call, the o2 must have 12 volts, please let us know what you find
Best, Ken
Oct 3, 2016 at 8:58 AM
SATURNTECH9
  • 30,869 POSTS
So did you ever check the compression?
Oct 3, 2016 at 12:23 PM
MIKEY300ZX
  • 10 POSTS
O2 sensor has 12v to heater and heater ground is good. When I apply voltage to the signal wire scan tool still doesn't pick up voltage. I'm going to trace it to the ecm and find a break. Has to be grounding out. At least that's my guess. Any ideas? Still can't get calculated load to come down. In my experience koeo calculated load should be 0% and I checked other cars I own to back myself up. Also going to check ecm grounds. Can't get my hands on an ecm pinout for some reason. All data doesn't have one.
Oct 4, 2016 at 8:49 AM
MIKEY300ZX
  • 10 POSTS
Also have not checked compression but did a leak down test had little to no leak at all.
Oct 4, 2016 at 8:50 AM
HMAC300
  • 48,601 POSTS
here is pcm pics best I can do you'll have to piece together because of size.
Oct 4, 2016 at 9:33 AM
MIKEY300ZX
  • 10 POSTS
Ok so I checked compression and did a leak down test. No compression on three cyl and 15 on one. Leakdown blowing air through all spark plug holes. Changing the head and gasket tomorrow via the customer. Thank you everyone have a grew weekend. Not sure why I didn't check compression first. What a dip shit moment.
Oct 7, 2016 at 2:59 PM
HMAC300
  • 48,601 POSTS
hey it happens sometimes you forge the simplest things.
Oct 7, 2016 at 3:16 PM
SATURNTECH9
  • 30,869 POSTS
I had a feeling about compression that's why I kept asking about compression.Sometimes we just over think things and think it just can't be that.
Oct 7, 2016 at 3:21 PM
MIKEY300ZX
  • 10 POSTS
The only reason I didn't was because it was running fine and shut off on me but I took the head off and it has a crack on both sides along with a bad gasket. Thanks for the input. Untill next time. I'm out. Thank you everyone!
Oct 7, 2016 at 4:40 PM
HMAC300
  • 48,601 POSTS
hey it happens to everyone done that several times
Oct 7, 2016 at 4:48 PM
