I ran out of gas the other day and pulled over. I put two gallons in and wouldn't turn over. Noticed it wouldn't go into neutral to push it. Added another gallon and still nothing. I had no issues with gas or any symptoms of a bad fuel pump. Always started right up and always has been very responsive and quick with the throttle. I did check the fuses and noticed the fuel pump relay fuse was blown as well as stop lamp switch, have switched those out with new ones. Also checked the inertia switch in the trunk as well.
May 26, 2019 at 12:18 PM
