Crank no start it backfired once?
2003 OLDSMOBILE ALERO
20,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
TLSTEELE 296
  • 6 POSTS
I just finished replacing the head gaskets and got everything back together got oil in it I don't have coolant in the motor yet. I just want to give you the background to bring you up to date LOL I went I charge the battery went cranking over Crank crank Crank but no start it backfired once. I noticed two vacuum lines sticking out one's black real small traced it back to the fuel pressure regulator I believe,..the other is real small and white and it came out of a a bunch that I thought were wires and anyway it's stuck in there and It was just poking out I took pictures and marked them if you could tell me where this white vacuum hose supposed to end up where it started and if I'm correct about the black one it goes from a pressure regulator to the it looks like a fuel filter on the fuel rail on the other end. Appreciate the help I'll send pictures also
Apr 6, 2026 at 9:47 AM
TLSTEELE 296
  • 6 POSTS
I just finished replacing the head gaskets and got everything back together got oil in it I don't have coolant in the motor yet. I just want to give you the background to bring you up to date LOL I went I charge the battery went cranking over Craig Craig Craig but no start it backfired once. I noticed two vacuum lines sticking out one's black real small traced it back to the fuel pressure regulator I believe the other is real small and white and it came out of a a bunch that I thought were wires and anyway it's stuck in there and I was just poking out I took pictures and marked them if you could tell me where this white vacuum hose supposed to end up where it started and if I'm correct about the black one it goes from a pressure regulator to the it looks like a fuel filter on the fuel rail on the other end. Appreciate the help I'll send pictures also
Apr 6, 2026 at 4:59 PM (Merged)
So the arrow on the intake manifold is a large vacuum leak so plug that or find the line that goes to it, the blue line goes to the fuel pressure regulator which is just in front of it, and the white line goes to the HVAC system and needs direct vacuum. Please send me a short video of the engine trying to start after that so I can see what is going on. Ken This video may help as well.
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
Apr 7, 2026 at 10:22 AM
TLSTEELE 296
  • 6 POSTS
Got the vacuum line figured out it fired several times but dies right away my exhaust is not connected I had to cut it to access rear head. I had to feather the pedal quite a bit to keep it going
Apr 8, 2026 at 12:37 PM
Thanks for the video, it looks like the firing order is wrong, I would double check that first. These images should help. Check out the images (below). Please let us know what happens.
Apr 9, 2026 at 6:19 AM
TLSTEELE 296
  • 6 POSTS
I ran the wires according to the diagram it starts but won't idle, still sounds like back firing
Apr 10, 2026 at 3:33 PM
Thanks for the video, it still sounds like the firing order it off, I would check it again. Also, UI have seen these kinds of ignition coils go bad and crossfire which can be the problem as well. Also, check the engine wiring harness grounds to the engine, if the system has a bad ground it will cause this issue as well, if everything looks okay run the codes, I seen the check engine light on, so codes are stored and get back to me, we are close to getting the engine running good.
Apr 11, 2026 at 7:48 AM
TLSTEELE 296
  • 6 POSTS
The only code that came up was P050 the wires are correct how would I check the ignition coils?
Apr 13, 2026 at 9:31 AM
TLSTEELE 296
  • 6 POSTS
Nevermind the code I'm getting is P0300
Apr 13, 2026 at 2:39 PM
Yep, random misfire. Is the coil grounded well? If the ignition control module goes out it will have this code. I would check the engine harness grounds, if one of them is not connected it will cause this issue as well, here is a guide to help you check the coils.
Apr 14, 2026 at 7:48 AM
