Engine cranks, no spark, no fuel pressure?
1997 CHEVROLET EXPRESS
193,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
FITPLUMBER
  • 7 POSTS
Engine cranks. No spark. No fuel pressure. I pulled the fuel pump relay and jumped 87 to 30 and fuel pump runs, builds pressure to 60 PSI. When the key is on, there is no power to the timed test circuit. Also, when the ECM-B fuse is in, there is a parasitic draw of 0.8 AMPS. When the fuse is pulled then amp draw goes down to 0.01 AMPS.
Feb 10, 2024 at 1:31 PM
If the battery does not dead after a couple of days don't worry about the draw. The system goes to sleep after a few minutes. For the not start problem it sounds like the crankshaft angle sensor has gone out because the PCM will not turn the fuel pump on if it does not see engine rotation, and no spark as well. Check the electrical connector as well because the wiring can get damaged due to the position of the sensor. Check out the images (below). Please upload pictures or videos in your response to the problem so we can see what's going on.
Feb 10, 2024 at 5:25 PM
FITPLUMBER
  • 7 POSTS
The draw on the battery drains it in 24 to 36 hours. This is not a normal condition. The draw never goes away. The fuel pump should run momentarily by just turning the key without attempting to turn the engine over. It does not. I don’t think this is the answer.
Feb 11, 2024 at 3:14 PM
FITPLUMBER
  • 7 POSTS
To say a little bit more, the answer I received sounds like my post was not read carefully. The fuel pump should come on momentarily when the key is turned without cranking, it does not. And the fuel pump works because I tested it and got pressure.
Feb 11, 2024 at 3:18 PM
Sorry about that, you are correct. I see now the ECM B fuse goes to the fuel pump, relay and the oil pressure sensor which controls the fuel pump as well. I would swap out the oil pressure sensor and fuel pump relay to see if the battery draw stops and the fuel pump starts working when the key is turned on. Here is the location of the sensor. Also, let's run the codes if this does not help.
Feb 12, 2024 at 9:21 AM
FITPLUMBER
  • 7 POSTS
I will check out your suggestions. Thank you.
Feb 15, 2024 at 3:21 AM
FITPLUMBER
  • 7 POSTS
One of my biggest questions is why there is never any power to the fuel pump prime connector. Where does the fuel pump prime connector get its power from? Is it from the power train control module?
Feb 15, 2024 at 3:53 AM
The ECM B fuse supplies power to the fuel pump test connector. Do you have power at the fuse, is the fuse good?
Feb 15, 2024 at 5:04 PM
FITPLUMBER
  • 7 POSTS
Yes, I have power at the fuse. The fuse is good.
Feb 16, 2024 at 1:50 AM
Do you have power at the grey wire at the oil pressure sensor/switch?
Feb 16, 2024 at 10:28 AM
FITPLUMBER
  • 7 POSTS
I will check this and respond.
Feb 18, 2024 at 3:41 AM
Sounds good.
Feb 19, 2024 at 8:39 AM
anything?
May 11, 2024 at 10:20 AM
