Crank no start, where is the fuel pump relay located?
2015 NISSAN VERSA
103,000 MILES • 1.6L
T.REVIS25
MEMBER
1 POST
FOLLOW
Where is the fuel pump relay located in the vehicle listed above S model?
Mar 27, 2025 at 2:22 AM
STEVE W.
CERTIFIED EXPERT
It is a non-replaceable part of the smart fuse box under the hood. You say it cranks but doesn't start? You might want to look at the service bulletin I attached.
I would also try using some starting fluid and see if it will fire on that. If not, then it may not be fuel related.
