Crank no start no power to crankshaft position sensor?
2008 MAZDA TRIBUTE
180,032 MILES • 4 CYL • 2WD • AUTOMATIC
HAYWOOD97
MEMBER
1 POST
FOLLOW
Shop said there's no power to crankshaft position sensor harness. I'm looking for wiring diagram or pinout for it, please and thank you.
Oct 16, 2024 at 5:55 PM
CERTIFIED EXPERT
Sure here are the wiring diagrams for the crankshaft angle sensor the PCM. I can say the power (5 volts) comes from the PCM itself, did they check the fuses is the rest of the 5 volts system down? Anyway, here you go, Check out the images (below). Please let us know what happens.
