Crank no start after car sat for two weeks
2006 NISSAN XTERRA
164,375 MILES • V6 • 2WD • AUTOMATIC
KATIE1984
  • 7 POSTS
Car sat for two weeks with dead battery now it is cranking but wont start. so we replaced crankshaft sensor, cam sensor check, all fuses and relay thru are good, starter good, alternator good, got new battery. no start all lights come on though. Someone said the computer in the car doesn't know what to do because it sat so long? We are out of ideas and money at this point.. Help please.
Apr 26, 2019 at 3:47 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, a vehicle needs three things to start, fuel, spark (delivered at the right time), and compression. If these three things are present, an engine has no choice but to start, So let's start eliminating these systems as the problem, until we find the problem one. So, let's start with spark. I have included a link down below for you to go to.
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Apr 27, 2019 at 12:29 PM
KATIE1984
  • 7 POSTS
No spark but fuel pump kicks on. A Nissan tech said the no spark could be due to the ECU computer security system.
Apr 27, 2019 at 12:40 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Is the security indicator lamp on your vehicle's dashboard illuminated?
Thanks,
Alex
2CarPros
Apr 27, 2019 at 1:55 PM
KATIE1984
  • 7 POSTS
It is on but it doesn't not stay on. The VDC light and slip light stay on.
Apr 27, 2019 at 3:42 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay,
If the security indicator lamp just comes on for lamp check then goes out, your vehicle's no start condition is not because of the security system. Okay, no spark, there's our problem. This could be a problem with your vehicle's Crankshaft Position Sensor (CKP). Your vehicle's Power-train Control Module (PCM) uses the signal from the CKP for crankshaft rotation(Engine RPM's) and for the misfire monitor. If the PCM doesn't get the CKP signal, it wont know that the engine is rotating, and therefore will not start it. I have included a few links below for you to go to:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Apr 27, 2019 at 5:49 PM
KATIE1984
  • 7 POSTS
The shifter is stuck in neutral. how can i fix this problem?
Apr 27, 2019 at 10:44 PM
KATIE1984
  • 7 POSTS
Now its security system. Help!!
Apr 29, 2019 at 8:50 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, this is sounding more and more like a ground problem. Today's vehicle's use a single ground for many electrical circuits on the vehicle. I have included in the diagrams down below a Ground Distribution Wiring Diagram and the locations of the two grounds I want you to inspect. They are Ground M57 and M61 respectively. To inspect these make sure that they are clean, corrosion free, tight, and are making good metal to metal contact. The same goes for the ring connectors that attach to the ground. Please check these grounds and get back to us with what you are able to find out .
Thanks,
Alex
2CarPros
Apr 29, 2019 at 9:30 PM
KATIE1984
  • 7 POSTS
Okay put new battery in new crankshaft sensor now the dash lights and everything come on but the radio and the car with key light is staying on! Help
May 2, 2019 at 1:37 AM
SCGRANTURISMO
  • 4,897 POSTS
Okay, I have included for you in the diagrams down below a comprehensive factory diagnostic troubleshooting guide for the immobilizer/anti-theft security system in your vehicle. You will need to use a multimeter do perform the steps in the guide, so I have included a link for you to go to if you are unfamiliar with how to use one.
Please go through the guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
May 2, 2019 at 6:31 AM
KATIE1984
  • 7 POSTS
Half of the fuse box isnt working but fuses are good do i need to replace the fuse box or ecu???
May 2, 2019 at 11:00 AM
